  • openmv的p7 或p8口好像坏了一个 ,控制不了舵机,我想用p9代替坏的那个,该怎么改代码啊
    • from pyb import Pin, Timer#导入引脚和定时器
      inverse_left=False #change it to True to inverse left wheel 初始化
      inverse_right=False #change it to True to inverse right wheel 初始化
      ain1 = Pin('P0', Pin.OUT_PP)#控制左右两边电机方向
      ain2 = Pin('P1', Pin.OUT_PP)
      bin1 = Pin('P2', Pin.OUT_PP)
      bin2 = Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)#设置定时器4 频率为1000hz
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      if inverse_left==False: #如果接反了正负 就取反修正
      left_speed=(-left_speed)
      if inverse_right==True:# 同上
      right_speed=(-right_speed)
      if left_speed < 0:
          ain1.low()
          ain2.high()
          ain1.high()
          ain2.low()
      ch1.pulse_width_percent(int(abs(left_speed)))
      if right_speed < 0:
          bin1.low()
          bin2.high()
          bin1.high()
          bin2.low()
      ch2.pulse_width_percent(int(abs(right_speed)))
    • 14,15行,把P7,或者P8,改成P9就行了。
