  • 根据追踪小球的小车的例子做了一个出来,但是发现小车并没有像视频里面那样和小球保持一段距离,识别到了就往前顶,
    • Blob Detection Example
      This example shows off how to use the find_blobs function to find color
      blobs in the image. This example in particular looks for dark green objects.
      import car
      green_threshold = (76, 96, -110, -30, 8, 66)
      size_threshold = 2000
      x_pid = PID(p=3, i=1, imax=100)
      h_pid = PID(p=0.22, i=0.1, imax=50)
          print("x error: ", x_error)
          for b in blobs:
          print("h_output",h_output)
          car.run(10,-10)
    • size_threshold 改小一些。
      如果目标比这个值小,就会往前走。
