  • 调用find_line函数之后,打印返回image.line的对象列表会报错,携带源码和报错图片,help
    • # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      sb = (8, 21, -36, 9, -11, 17)
      ng=(29, 81, 30, 80, 30, 80)# generic_green_thresholds
      THRESHOLD=(70, 0, -128, 127, -128, 127)
          blobsb=img.find_blobs([sb], pixels_threshold=200, area_threshold=200)
          blobng=img.find_blobs([ng], pixels_threshold=200, area_threshold=200)
          if blobsb or blobng:
              for s in blobsb:
                  img.draw_cross(s.cx(), s.cy())
                  #img.draw_rectangle(s.rect())
              for blobn in  blobng:
                  img.draw_cross(blobn.cx(), blobn.cy())
                  #img.draw_rectangle(blobn.rect())
                  img.draw_line(s.cx(), s.cy(),blobn.cx(), blobn.cy(), color = [0, 0, 255])
                  #img.binary([THRESHOLD])
                  line=img.find_line_segments()
                  if (line):
                      if line.theta()>90:
                          theta_err = line.theta()-180
                      print(line.theta())
              #img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=20)
    • line=img.find_line_segments()
      这里返回的是数组,应该是
      lines=img.find_line_segments()
      for line in lines:
          pass
