U盘自动弹出导致连接断开,不产生数据,是为什么?
使用edge impluse训练模型产生的.py文件在IDE中运行,当识别到数据时U盘自动弹出导致连接断开,不产生数据,是为什么?
代码正常,当摄像头拍摄别的物体时,正常传输概率数据,当拍摄并识别到我的人脸时,就自动断开连接。# Edge Impulse - OpenMV Image Classification Example import sensor, image, time, os, tf sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((240, 240)) # Set 240x240 window. sensor.skip_frames(time=2000) # Let the camera adjust. net = "trained.tflite" labels = [line.rstrip('\n') for line in open("labels.txt")] clock = time.clock() while(True): clock.tick() img = sensor.snapshot() # default settings just do one detection... change them to search the image... for obj in tf.classify(net, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5): print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect()) img.draw_rectangle(obj.rect()) # This combines the labels and confidence values into a list of tuples predictions_list = list(zip(labels, obj.output())) for i in range(len(predictions_list)): print("%s = %f" % (predictions_list[i][0], predictions_list[i][1])) print(clock.fps(), "fps")
固件版本是多少?硬件用的是什么?
固件版本4.0.2(最新),硬件OPENMV4PLUS
使用OPENMV3代入例程正常,使用4PLUS代入例程以及之前写的程序也正常,是否是因为此代码运算量过大或其他原因导致IDE bug?
