Servo(3)不存在怎么解决
from pyb import Servopan_servo=Servo(1)
tilt_servo=Servo(2)
s3=Servo(3)
tilt_servo.calibration(500,2500,500)red_threshold = (13, 49, 18, 61, 6, 47)
#tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PIDsensor.reset() # Initialize the camera sensor.
clock = time.clock() # Tracks FPS.def find_max(blobs):
return max_blobwhile(True):
img = sensor.snapshot() # Take a picture and return the image.blobs = img.find_blobs([red_threshold]) if blobs: max_blob = find_max(blobs) pan_error = max_blob.cx()-img.width()/2 tilt_error = max_blob.cy()-img.height()/2 print("pan_error: ", pan_error) img.draw_rectangle(max_blob.rect()) # rect img.draw_cross(max_blob.cx(), max_blob.cy()) # cx, cy pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output)
型号是OpenMV4 H7 Plus
