  • 有线图传显示无法显示xga画质?
    • 使用有线图传显示,画质为xga,显示不完整且运行一会就卡死,是硬件不支持吗,需要怎样才能显示xga图像
      # Barcode Example
      # This example shows off how easy it is to detect bar codes using the
      # OpenMV Cam M7. Barcode detection does not work on the M4 Camera.
      import sensor, image, time, math,tv
      from pyb import Pin, Timer
      # 50kHz pin6 timer2 channel1
      #light = Timer(2, freq=50000).channel(1, Timer.PWM, pin=Pin("P6"))
      #light.pulse_width_percent(10) # adjust light 0~100
      sensor.set_framesize(sensor.XGA) # High Res!
      sensor.set_windowing((1000, 400))# V Res of 80 == less work (40 for 2X the speed).
      tv.init() # 初始化tv
      tv.channel(8) # 用于无线图传扩展板
      # Barcode detection can run at the full 640x480 resolution of your OpenMV Cam's
      # OV7725 camera module. Barcode detection will also work in RGB565 mode but at
      # a lower resolution. That said, barcode detection requires a higher resolution
      # to work well so it should always be run at 640x480 in grayscale...
      def barcode_name(code):
              return "EAN2"
              return "EAN5"
              return "EAN8"
              return "UPCE"
              return "ISBN10"
              return "UPCA"
              return "EAN13"
              return "ISBN13"
          if(code.type() == image.I25):
              return "I25"
              return "DATABAR"
              return "DATABAR_EXP"
              return "CODABAR"
              return "CODE39"
              return "PDF417"
              return "CODE93"
              return "CODE128"
          codes = img.find_barcodes()
          codeh = 0
          y = 10000000
          print(len(codes))
          if (len(codes)>1):
              for code in codes:
                  img.draw_rectangle(code.rect())
                  y1 =code.y()
                  print(y1)
                  if(y1<y):
                      y = y1
                      codeh = code
              if(codeh != ""):
                  print_args = (barcode_name(codeh), codeh.payload(), (180 * codeh.rotation()) / math.pi, codeh.quality(), clock.fps())
                  print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args)
              for code in codes:
                  codeh = code
          #img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens.
              print(code)
          tv.display(img)
          if not codes:
              print("FPS %f" % clock.fps())
    • 图传扩展板的分辨率不支持xga。最高就是352x240。
    • @kidswong999请教一下大大 如果需要外接显示xga需要通过什么方式
    • @kidswong999 请教一下大大 如果需要外接显示xga需要通过什么方式
    • 现在没有大的屏幕。
    • @kidswong999 请教一下大大 openmv有没有类似opencv 的resize函数 我把xga的图像压缩成352x240再显示
    • img.crop()有scale参数:
          img.crop(x_scale=0.3125, y_scale=0.3125)
    • @kidswong999 请教一下大大,现在图片测试程序是可以到缩放到325x240,可以正常显示,但是代入程序后显示还是卡死,如何解决?
      测试代码
      import sensor, image, time ,tv
      tv.init() # 初始化tv
          img.crop(x_size=325, y_size=240)
          tv.display(img)
      代入代码
      # Barcode Example
      tv.init() # 初始化tv
              return "EAN2"
              return "EAN5"
              return "EAN8"
              return "UPCE"
              return "ISBN10"
              return "UPCA"
              return "EAN13"
              return "ISBN13"
              return "I25"
              return "DATABAR"
              return "CODABAR"
              return "CODE39"
              return "PDF417"
              return "CODE93"
              return "CODE128"
          codeh = 0
          y = 10000000
          print(len(codes))
          if (len(codes)>1):
              for code in codes:
                  y1 =code.y()
                  print(y1)
                  if(y1<y):
                      y = y1
                      codeh = code
              if(codeh != ""):
              for code in codes:
                  codeh = code
              print(code)
          img.crop(x_scale=0.352, y_scale=0.6)
          tv.display(img)
          if not codes:
    • @kidswong999 加入压缩图片函数 代入代码后也是无法显示 img.compressed(1)
    • 我运行测试代码没有出现错误
      固件版本:4.0.1
      硬件:OpenMV4 Plus, OV5640
    • @kidswong999 好的 我寄回去测试吧 感谢大大
