  • #追踪小球的小车 使用测试代码报错can not import name Timer?
      代码如下
      #car.py
      from pyb import Pin, Timer
      inverse_left=False  #change it to True to inverse left wheel
      ain1 =  Pin('P0', Pin.OUT_PP)
      ain2 =  Pin('P1', Pin.OUT_PP)
      bin1 =  Pin('P2', Pin.OUT_PP)
      bin2 =  Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
          if inverse_left==True:
              left_speed=(-left_speed)
          if inverse_right==True:
              right_speed=(-right_speed)
          if left_speed < 0:
              ain1.low()
              ain2.high()
              ain1.high()
              ain2.low()
          ch1.pulse_width_percent(int(abs(left_speed)))
          if right_speed < 0:
              bin1.low()
              bin2.high()
              bin1.high()
              bin2.low()
          ch2.pulse_width_percent(int(abs(right_speed)))
      #main.py
      import car
          car.run(100,100)
    • 升级到最新的固件。
