  • 为什么通过串口发送条形码payload的内容有时候会报这个错,有时候又不报.
      codes = img.find_barcodes()
          for code in codes:
              img.draw_rectangle(code.rect())
              print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps())
              print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args)
             # Message.UartSendData(bytearray([0xAA,0x29,0x05,0x45,0x01,int(code.payload()),0x01]))
              data =float(code.payload().replace('\ufeff',''))
              Message.UartSendData(Message.BarDataPack(int(data)))
              print("条形码发送已完成")
    • 原因:因为你的data有时候不是数字的字符串,可能是识别错误。你看串行终端里上面的输出是"‘",不是"1"
