  • 没脱机前运行正常,脱机后运行到舵机处,会自动复位(异常)。
    • main.py
      import pyb, sensor, time, image
      from pyb import Pin,Timer
      LED_b = pyb.LED(3)
      LED_g = pyb.LED(2)
      Servo_PWM = Pin('P7')
      pwma = Pin('P8')
      pwmb = Pin('P9')
      tim1 = Timer(4, freq=400)
      ch1 = tim1.channel(1, Timer.PWM, pin=Servo_PWM)
      ch2 = tim1.channel(2, Timer.PWM, pin=pwma)
      ch3 = tim1.channel(3, Timer.PWM, pin=pwmb)
      ch1.pulse_width_percent(60)
      ch2.pulse_width_percent(0)
      ch3.pulse_width_percent(0)
      thresholds = [(90, 100, -128, 127, -128, 127)]
      sensor.skip_frames(time = 50)
      sensor.set_auto_gain(False)
      sensor.set_auto_exposure(False, 1400)
      def DrawImg():
      	blobs = img.find_blobs([thresholds[0]])
      	if len(blobs)==1:
      		b = blobs[0]
      		img.draw_rectangle(b[0:4])
      		img.draw_cross(b[5], b[6])
      		return b
      K = 290
      def DistenceMeasure(b):
      	Lm = (b[2]+b[3])/2
      	Distence = K/Lm
      	return Distence
      def Angle(b):
      	delta_x = b[5] - 160
      	Sita= delta_x*180/320+135
      	return Sita
      def MY_Angle(Sita):
      	Servo_ht = Sita/270*2+0.5
      	Servo_pwm = Servo_ht/2.5*100
      	ch1.pulse_width_percent(int(Servo_pwm))
      	b1 = DrawImg()
      	if(b1 == None):
      		LED_g.off()
      		LED_b.on()
      		LED_b.off()
      		LED_g.on()
      		D = DistenceMeasure(b1)
      		Sita = Angle(b1)
      		print(Servo_pwm)
    • 自动复位是OpenMV重启,还是舵机复位?
    • 你看一下电源供电是否正确。
