  • EDGE生成的代码出现错误
    • OSError: Arena size is too small for activation buffers. Needed 225840 but only 156272 was available怎么解决?
      sensor.set_framesize(sensor.QQVGA)      # Set frame size to QVGA (320x240)
      #sensor.set_windowing((240, 240))       # Set 240x240 window.
      net = "trained.tflite"
          print(clock.fps(), "fps")
    • edge impulse只能OpenMNV4 Plus才能使用。
