在使用for遍历之前加上while之后帧缓存区卡死,程序仍在进行?
c=1 while c<=6: #print(type(s)) a=s.replace('+','') #print(a) if c==1: num=a[0] print(num) if c==2: num=a[1] print(num) if c==3: num=a[2] print(num) if c==4: num=a[3] print(num) if c==5: num=a[4] print(num) if c==6: num=a[5] print(num) clock = time.clock() img = sensor.snapshot().lens_corr(1.8) blobs = img.find_blobs([red_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); blobs1 = img.find_blobs([green_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); blobs2 = img.find_blobs([blue_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); cx=0;cy=0;cx1=0;cy1=0;cx2=0;cy2=0; for R in img.find_rects(threshold = 10000): for p in R.corners(): img.draw_circle(p[0], p[1], 5, color = (0, 255, 0)) area = (R.x(),R.y(),R.w(),R.h()) statistics = img.get_statistics(roi=area)#像素颜色统计 #print(statistics) if num=='1': #red while(1): print('red') if 0<statistics.l_mode()<100 and 7<statistics.a_mode()<127 and -128<statistics.b_mode()<127:#若矩形是红色 img.draw_rectangle(R.x(), R.y(), R.w(),R.h(), color = (255, 0, 0)) if blobs: #定位 #如果找到了目标颜色 for blob in blobs: img.draw_cross(blob[5], blob[6]) # cx, cy img.draw_cross(160, 120) # 在中心点画标记 #在目标颜色区域的中心画十字形标记 cx=blob[5]; cy=blob[6]; img.draw_line((160,120,cx,cy), color=(127)); img.draw_string(cx, cy, "(%d, %d)"%(cx,cy), color=(127)); word=print(cx,cy) #uart.write(cx,cy) word_0='word' time.sleep_ms(5000)
你的代码不是完整代码,不能运行的。
