  • 为啥转弯不是很灵敏,而且不会向左转弯
    • # Blob Detection Example
      import utime
      import car
      green_threshold   = (48, 76, 0, 78, 42, 74)
      size_threshold = 2000
      #        utime.sleep_ms(0)
              print("x error: ", x_error)
              for b in blobs:
              print("h_output",h_output)
              car.run(26,-26)
