  • 为啥转弯不是很灵敏,而且不会向左转弯
    • # Blob Detection Example
      # This example shows off how to use the find_blobs function to find color
      # blobs in the image. This example in particular looks for dark green objects.
      import utime
      import car
      green_threshold   = (48, 76, 0, 78, 42, 74)
      size_threshold = 2000
      x_pid = PID(p=0.5, i=1, imax=100)
      h_pid = PID(p=0.05, i=0.1, imax=50)
      #        utime.sleep_ms(0)
              max_blob = find_max(blobs)
              x_error = max_blob[5]-img.width()/2
              h_error = max_blob[2]*max_blob[3]-size_threshold
              print("x error: ", x_error)
              for b in blobs:
              img.draw_rectangle(max_blob[0:4]) # rect
              img.draw_cross(max_blob[5], max_blob[6]) # cx, cy
              x_output=x_pid.get_pid(x_error,1)
              h_output=h_pid.get_pid(h_error,1)
              print("h_output",h_output)
              car.run(-h_output-x_output,-h_output+x_output)
              car.run(26,-26)
