  • 买的追踪绿色小车套件,代码没动,但是现在屏幕中出现绿色就报错,这是怎么回事?
      import car
      sensor.skip_frames(10)
      green_threshold   = (76, 96, -110, -30, 8, 66)
      size_threshold = 2000
      		print("x error: ", x_error)
      		img.draw_rectangle(max_blob[0:4])
      		img.draw_cross(max_blob[5], max_blob[6])
      		print("h_output",h_output)
      		car.run(18,-18)
    • from pyb import Pin, Timer
      inverse_left=False
      inverse_right=False
      ain1 =  Pin('P0', Pin.OUT_PP)
      ain2 =  Pin('P1', Pin.OUT_PP)
      bin1 =  Pin('P2', Pin.OUT_PP)
      bin2 =  Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      	if inverse_left==True:
      		left_speed=(-left_speed)
      	if inverse_right==True:
      		right_speed=(-right_speed)
      	if left_speed < 0:
      		ain1.low()
      		ain2.high()
      		ain1.high()
      		ain2.low()
      	if right_speed < 0:
      		bin1.low()
      		bin2.high()
      		bin1.high()
      		bin2.low()
    • from pyb import millis
      from math import pi, isnan
      class PID:
      	_RC = 1/(2 * pi * 20)
      		self._kp = float(p)
      		self._ki = float(i)
      		self._kd = float(d)
      		self._imax = abs(imax)
      		tnow = millis()
      		dt = tnow - self._last_t
      		output = 0
      			dt = 0
      			self.reset_I()
      		self._last_t = tnow
      		output += error * self._kp
      				derivative = 0
      				self._last_derivative = 0
      			self._last_error = error
      		output *= scaler
      			output += self._integrator
      		return output
      	def reset_I(self):
      		self._integrator = 0
    • 更新一下代码:
      https://book.openmv.cc/project/zhui-xiao-qiu-de-xiao-8f665d28-project-pan-tilt-md.html
      car.py改成网页里的就行。
