  • 寻迹小车线性回归线没有显示,也没有回归作用,官方这代码有问题?????
      THRESHOLD = (34, 0, -17, 6, -2, 18) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      sensor.set_vflip(True)
      sensor.set_hmirror(True)
          if (line):
              if line.theta()>90:
                  theta_err = line.theta()-180
              if line.magnitude()>8:
                  car.run(50+output, 50-output)
                  car.run(0,0)
              car.run(50,-50)
              pass
          #print(clock.fps())
      还有car.py和pid.py文件导入可试
    • @nzdc 没有报错信息,就是回归直线功能不显示也没效果,小车一直走。。
