之前串口没有问题,今天串口上传数据乱码。会不会是硬件问题
Single Color RGB565 Blob Tracking Example
This example shows off single color RGB565 tracking using the OpenMV Cam.
threshold_index = 0 # 0 for red, 1 for green, 2 for blue QVGA320
thresholds = [(100, 100, 0, 3, 3, 0), # generic_red_thresholds
(255,255), # generic_green_thresholds 30,255
(0, 30, 0, 64, -128, 0)] # generic_blue_thresholds RGB565 GRAYSCALEsensor.reset()
sensor.set_pixformat(sensor.GRAYSCALE) #sensor.GRAYSCALE
sensor.set_framesize(sensor.VGA) #sensor.VGA
uart = UART(3,57600)
mx=0
my=0
for blob in img.find_blobs([thresholds[1]], pixels_threshold=10, area_threshold=10, merge=True):if blob.cx() > 100 : img.draw_rectangle(blob.rect()) img.draw_cross(blob.cx(), blob.cy()) #str(blob.cx())+','+str(blob.cy()) uart.write('{'+str(blob.cx())+','+str(blob.cy())+'}') print('{'+str(blob.cx())+','+str(blob.cy())+'}') #uart.write(str(blob.cx())+','+str(blob.cy())+';')
解决了,串口接地就没有乱码了。
请问怎么可以把数据传输出去呢
