openmv跟arduino脱机通信出问题
问题就是,我openmv插上电脑USB供电的时候,arduino那边接受到我扫码的都是正常的,我脱机后,通上电,arduino那边会接受0,但是openmv此时还在扫码,没发送信息过去
import time import sensor, image, time import json import pyb from pyb import UART global zuo,zhong,you zuo=0 zhong=0 you=0 yellow_threshold = ( 46, 100, -68, 72, 58, 92) red_threshold =(39, 4, 67, 43, -29, 69)#红色颜色阈值 green_threshold = (28, 4, -45, -8, -73, 47)#绿色颜色阈值 blue_threshold=(46, 4, 53, -82, -113, -34)#蓝色颜色阈值 #blue_threshold=(29, 49, -50, 25, -63, -35) red_color_code = 1 # code = 2^0 = 1 green_color_code = 2 # code = 2^1 = 2 blue_color_code = 4 #code=2^2=4 black_color_code = 8 #code=2^3=8 led = pyb.LED(3) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... clock = time.clock() uart = UART(3, 9600, timeout_char = 1000) uart.init(9600, bits=8, parity=None, stop=1) c=d=1 while(b2==1): uart = UART(3, 9600, timeout_char = 1000) uart.init(9600, bits=8, parity=None, stop=1) clock.tick() img = sensor.snapshot() img.lens_corr(0.8) # strength of 1.8 is good for the 2.8mm lens. for code in img.find_qrcodes(): data_out = code.payload() if data_out: uart.write(data_out) print(data_out) b2=2
看看接线有没有问题,GND有没有连起来。
@kidswong999 我们后面试出来,是接收端那边的问题,那边输入模式设置错了
