  • openmv h7 plus 实例里面的代码 驱动舵机是出现问题
    • 买了舵机拓展板,没有焊接就是直接插上去。0_1ng
      这是main中编的代码
      Servo Shield Example.
      This example demonstrates the servo shield. Please follow these steps:
      1. Connect a servo to any PWM output.
      2. Connect a 3.7v battery (or 5V source) to VIN and GND.
      3. Copy pca9685.py and servo.py to OpenMV and reset it.
      4. Connect and run this script in the IDE.
      from servo import Servos
      from machine import I2C, Pin
      servo.position(0, 0)
      time.sleep_ms(500)
      servo.position(0, 180)
      time.sleep_ms(500)
    • OpenMV的插针肯定要焊接的,没焊接用不了。https://singtown.com/learn/50057/
