星瞳实验室APP,快速收到回复
  • 有懂得老哥吗,小弟不知道怎么处理这个
    • 0_1616663005424_274ccd8e-cb62-435d-9219-db8b16202f8e-image.png ☹
    • #car.py
      from pyb import Pin, Timer
      ain1 = Pin('P0', Pin.OUT_PP)
      ain2 = Pin('P1', Pin.OUT_PP)
      bin1 = Pin('P2', Pin.OUT_PP)
      bin2 = Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      if inverse_left==True:
      left_speed=(-left_speed)
      if inverse_right==True:
      right_speed=(-right_speed)
      if left_speed < 0:
          ain1.low()
          ain2.high()
          ain1.high()
          ain2.low()
      if right_speed < 0:
          bin1.low()
          bin2.high()
          bin1.high()
          bin2.low()
    • #pid.py
      from pyb import millis
      from math import pi, isnan
      class PID:
      _RC = 1/(2 * pi * 20)
      def init(self, p=0, i=0, d=0, imax=0):
      self._kp = float(p)
      self._ki = float(i)
      self._kd = float(d)
      self._imax = abs(imax)
          tnow = millis()
          dt = tnow - self._last_t
          output = 0
              dt = 0
              self.reset_I()
          self._last_t = tnow
          output += error * self._kp
                  derivative = 0
                  self._last_derivative = 0
              self._last_error = error
          output *= scaler
              output += self._integrator
          return output
      def reset_I(self):
          self._integrator = 0
    • #tracking.py
      THRESHOLD = (0,100) # Grayscale threshold for dark things...
      from pyb import LED
      import car
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      BINARY_VISIBLE = True # 首先执行二进制操作,以便您可以看到正在运行的线性回归...虽然可能会降低FPS。
      # to process a frame sometimes.
      line = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD])
      if (line):
      if line.theta()>90:
      theta_err = line.theta()-180
      if line.magnitude()>0:
      car.run(50+output, 50-output)
      car.run(0,0)
      car.run(50,-50)
      pass
      #print(clock.fps())
    • 改为:ch1.pulse_width_percent(int(abs(left_speed)))
      就是多一个int函数。
