  • 这个可以在Linux系统内运行的如何用openmv写出来?
    • def uart_formate_ocu_spd_remote():#速度遥控命令
          global rx_data,tx_data,rx_cnt,rx_num_now,uartState,print_cnt,BYTE0,BYTE1,BYTE2,BYTE3
          global Baudrate,COM,Stopbits,ser,ReadUARTThread,cond_d,stop_d
          sum = 0
          _cnt = 0
          data_to_send  =  []
          data_to_send.append(0xAA)
          data_to_send.append(0xAF)
          data_to_send.append(0x32)#机器人参数
          data_to_send.append(0)
          send_char(data_to_send,88)#88
          send_float(data_to_send,gl.get_value('OCU_SPD_XY')[0])#
          send_float(data_to_send,gl.get_value('OCU_SPD_XY')[1])#
          send_float(data_to_send,gl.get_value('OCU_ATT_PR')[0])#
          send_float(data_to_send,gl.get_value('OCU_ATT_PR')[1])#
          send_float(data_to_send,gl.get_value('OCU_YAW_RATE'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_START'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_BACK'))#
          send_int(data_to_send,gl.get_value('OCU_CMD_LR'))#
          send_int(data_to_send,gl.get_value('OCU_CMD_FB'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_X'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_Y'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_B'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_A'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_LL'))#
          send_char(data_to_send,gl.get_value('OCU_CMD_RR'))#
          _cnt = len(data_to_send)
          data_to_send[3] = _cnt - 4
          for i in range(0,_cnt):
              sum = sum+ data_to_send[i]
          data_to_send.append(BYTE0(int(sum)))
          tx_data[0:len(data_to_send)]= data_to_send
          gl.set_value('UART_TX_LEN',len(data_to_send))
          return len(data_to_send)
    • 你具体要做什么?我没看懂。🤣
    • 这段程序里面哪些是和串口通讯协议有关的啊?
