  • 为什么识别红色物块,绿色物块都很好,但是蓝色就识别不出来
    • # Multi Color Blob Tracking Example
      # This example shows off multi color blob tracking using the OpenMV Cam.
      # The below thresholds track in general red/green things. You may wish to tune them...
                    (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
      # You may pass up to 16 thresholds above. However, it's not really possible to segment any
      # scene with 16 thresholds before color thresholds start to overlap heavily.
      # camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
          for blob in img.find_blobs(thresholds, pixels_threshold=1000, area_threshold=1000):
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255,0,0))
                  img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  img.draw_line(blob.minor_axis_line(), color=(0,0,255))
          #print(clock.fps())
              print(blob.code())
    • 那就是阈值没调好啊,重新改阈值
