  • 如何在一段代码中实现图像灰度模式和rgb模式之间的转换?
      from pyb import UART#串口用5V电压亦可
      sensor.set_pixformat(sensor.GRAYSCALE)#灰度图更快
      while not uart.any():
          #uart.write("0000\r\n")
              uart.write(code.payload())
              print(code.payload())
      red_threshold = (25, 82, 0, 64, 65, 6) # red_thresholds
      green_threshold  = (58, 33, -78, -16, 110, -71)# green_thresholds
      blue_threshold  = (28, 81, -52, 81, -29, -87)# blue_thresholds
      sensor.set_auto_whitebal(False)#关闭自动白平衡
      sensor.set_auto_gain(False)#关闭自动增益
          for blob in img.find_blobs([red_threshold], pixels_threshold=200, area_threshold=200):
              print('r')
          for blob in img.find_blobs([green_threshold], pixels_threshold=200, area_threshold=200):
              g=blob.cx()
              print('g')
          for blob in img.find_blobs([blue_threshold], pixels_threshold=200, area_threshold=200):
              b=blob.cx()
              print('b')
