如何获取一个像素点的LAB值
如何获取一个像素点的LAB值
image.get_pixel()函数只能获取RGB
https://docs.singtown.com/micropython/zh/latest/openmvcam/library/omv.image.html#image.rgb_to_lab
用函数转换一下。
用这个函数会报错呢?请问是为什么呢
import sensor, image, time sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time = 2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS. while(True): clock.tick() # Update the FPS clock. img = sensor.snapshot() # Take a picture and return the image. pixel_rgb = img.get_pixel(0,0) print(pixel_rgb) pixel_lab = image.rgb_to_lab(pixel_rgb) print(pixel_lab)
直接用模块名,不用实例名调用
