  • 追其他物体的小车 使用模板检测'int' object isn't subscriptable? 如何更改呢?
    • # Blob Detection Example
      import car
      green_threshold   = (76, 96, -110, -30, 8, 66)
      size_threshold = 2000
      template = image.Image("/qiu.pgm")
          blobs = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
              x_error = max_blob[0]+max_blob[2]/2-img.width()/2
              print("x error: ", x_error)
              for b in blobs:
              img.draw_cross(int(max_blob[0]+max_blob[2]/2),int( max_blob[1]+max_blob[3]/2)) # cx, cy
              print("h_output",h_output)
              car.run(18,-18)
    • find_template返回的是一个,而不是多个。
          if blob:
                  x_error = blob[0]+blob[2]/2-img.width()/2
                  h_error = blob[2]*blob[3]-size_threshold
                  img.draw_rectangle(blob) # rect
                  img.draw_cross(int(blob[0]+blob[2]/2),int(blob[1]+blob[3]/2)) # cx, cy
