请问这个code,payload()输出的是什么类型的数据啊?
请问这个扫码识别得到的code.payload(),扫码结果是123+321 ,我将它赋值给message,然后通过比对message是否等于字符串123+321,一直显示不相等,请问这个code,payload()输出的是什么类型的数据啊?
while(b==1): img = sensor.snapshot() img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens. for code in img.find_qrcodes(): img.draw_rectangle(code.rect(), color = (255, 0, 0)) message = code.payload() if message =='123+321' print("0")
就是字符串,估计你的代码写错了,或者是二维码错了。
# QRCode Example # # This example shows the power of the OpenMV Cam to detect QR Codes # without needing lens correction. import sensor, image, time sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.VGA) sensor.set_windowing((240, 240)) # look at center 240x240 pixels of the VGA resolution. sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... clock = time.clock() while(True): clock.tick() img = sensor.snapshot() for code in img.find_qrcodes(): if code.payload() == '123+321': print("yes")
