如何判断串口发送与接收过程中 信息是没有丢失的?
import time from pyb import UART uart = UART(3, 19200) while(True): uart.write("Hello World!\r") if uart.any() : a = uart.readline().decode() print(a))
使用uart函数接收与发送,这个过程需要判断数据是否完整吗?
那需要添加校验的数据,需要自己订一套协议。
此回复已被删除!
@kidswong999 请教一下,您说的自己定制协议,是指在我的数据中加入协议吗?比如说在数据中加入特殊符号,然后在接收端去判断数据是否完整吗?
对,你可以用
和校验
,crc校验
@kidswong999 感谢
此回复已被删除!
@kidswong999 microPython中找不到和校验和和crc的方法
import sensor, image, time ,tv from pyb import UART import hashlib from pyb import Pin, Timer sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... clock = time.clock() uart = UART(3, 19200) tv.init() # 初始化tv # 50kHz pin6 timer2 channel1 #light = Timer(2, freq=18000).channel(1, Timer.PWM, pin=Pin("P6")) #light.pulse_width_percent(100) # adjust light 0~100 def char_checksum(data, byteorder='little'): ''' char_checksum 按字节计算校验和。每个字节被翻译为带符号整数 @param data: 字节串 @param byteorder: 大/小端 ''' length = len(data) checksum = 0 for i in range(0, length): x = int.from_bytes(data[i:i+1], byteorder, signed=True) if x>0 and checksum >0: checksum += x if checksum > 0x7F: # 上溢出 checksum = (checksum&0x7F) - 0x80 # 取补码就是对应的负数值 elif x<0 and checksum <0: checksum += x if checksum < -0x80: # 下溢出 checksum &= 0x7F else: checksum +=x # 正负相加,不会溢出 #print(checksum) return checksum while(True): clock.tick() img = sensor.snapshot() #使用无畸变镜头 #img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens. for code in img.find_qrcodes(): img.draw_rectangle(code.rect(), color = (255, 0, 0)) print(code.payload()) sum1 = char_checksum(code.payload()) print(sum1) if code.payload() is not None : uart.write(code.payload() + "\r") tv.display(img) if uart.any() : a = uart.readline().decode() print(a)
https://github.com/openmv/openmv/blob/master/scripts/libraries/modbus.py
https://github.com/openmv/openmv/blob/master/scripts/libraries/rpc.py参考modbus.py和rpc.py里面的crc
@kidswong999 感谢
