ValueError: Timer(4) is reserved 追球小车
我做的追球小车,按视频的步骤来,为啥显示ValueError: Timer(4) is reserved
代码
from pyb import Pin, Timer
inverse_left=False
inverse_right=False
ain1 = Pin('P0', Pin.OUT_PP)
ain2 = Pin('P1', Pin.OUT_PP)
bin1 = Pin('P2', Pin.OUT_PP)
bin2 = Pin('P3', Pin.OUT_PP)
ain1.low()
ain2.low()
bin1.low()
bin2.low()
pwma = Pin('P7')
pwmb = Pin('P8')
tim = Timer(4, freq=1000)
ch1.pulse_width_percent(0)
ch2.pulse_width_percent(0)
if inverse_left==True:
left_speed=(-left_speed)
if inverse_right==True:
right_speed=(-right_speed)
if left_speed < 0:
ain1.low()
ain2.high()
ain1.high()
ain2.low()
if right_speed < 0:
bin1.low()
bin2.high()
bin1.high()
bin2.low()
你用的是什么硬件电路板?
另外IDE该更新了。
