代码运行几秒,摄像头画面就卡住,程序终止,在别人那里就正常运行,一直识别,想问问怎么解决
import sensor, image, time sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) #在色块检测模式下关闭自动补光 from pid import PID from pyb import Servo clock = time.clock() from pyb import UART import ustruct enable_lens_corr = False """ #以下三排根据需求更改 red_threshold_01 = ((35, 100, 41, 77, 24, 59)); green_threshold_01 = ((50, 100, -80, -20, 8, 20)); blue_threshold_01 = ((20, 100, -18, 18, -80, -30)); """ red_threshold_01 = ((35, 100, 41, 77, 24, 59)); green_threshold_01 = ((50, 100, -80, -20, 8, 17)); blue_threshold_01 = ((46, 95, -34, 19, -45, -11)); thresholds = [(0, 50, -24,-1, -18, 6)] pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID #tilt_pid = PID(p=0.05, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID #pan_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID uart = UART(3,115200) uart.init(115200, bits=8, parity=None, stop=1) k=12400 #********************k的值需要实际计算********* 距离*像素宽 单位是厘米 kk=0.326 #直径/像素宽 单位是厘米 def sending_data(flag,cr,yell,k2,k4): global uart; data = ustruct.pack("<bbhhhhhb", #b signed char 整数 1 0x2C, #h short 整数 2 0x12, #i int 整数 4 int(flag), int(cr), int(yell), int(k2), int(k4), 0x5B) uart.write(data); def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() img = sensor.snapshot().lens_corr(1.8) blobs = img.find_blobs([red_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); blobs1 = img.find_blobs([green_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); blobs2 = img.find_blobs([blue_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10); cx=0;cy=0;cr=0;flag=0;yellow=0;k2=0;k4=0; if blobs: yellow = 1; #R elif blobs1: yellow = 2; #G else: yellow = 3; #B print("yellow", yellow) for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2): if yellow==1: img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0)) elif yellow==2: img.draw_circle(c.x(), c.y(), c.r(), color = (0, 255, 0)) else : img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 255)) cx = c.x(); cy = c.y(); cr = c.r(); #k1=k/2/cr #圆形实际长度=k/圆形直径的像素点长度 k2=kk*2*cr #距离=kk*圆形直径的像素点长度 flag = 1; #print("距离为",k1,"厘米") print("直径为",k2,"厘米") time.sleep(100) print("圆形",c) break for r in img.find_rects(threshold = 15000): if yellow==1: img.draw_rectangle(r.rect(), color = (255, 0, 0)) #for p in r.corners(): img.draw_circle(p[0], p[1], 5, color = (255, 0, 0)) elif yellow==2: img.draw_rectangle(r.rect(), color = (0, 255, 0)) # for p in r.corners(): img.draw_circle(p[0], p[1], 5, color = (0, 255, 0)) else: img.draw_rectangle(r.rect(), color = (0, 0, 255)) # for p in r.corners(): img.draw_circle(p[0], p[1], 5, color = (0, 0, 255)) cx = int(r.x()+(r.w()/2)) cy = int(r.y()+(r.h()/2)) flag =2 print(r) print("矩形: x:",r.x()+(r.w()/2),"y:",int(r.y()+(r.h()/2))) time.sleep(100) #k3=k/cx #矩形实际长度=k/矩形像素点长度 k4=kk*cx #距离=kk*矩形直径的像素点长度 #print("距离为",k3,"厘米") print("长度为",k4,"厘米") break for s in img.find_line_segments(merge_distance = 10, max_theta_diff = 10): if yellow==1: img.draw_line(s.line(), color = (255, 0, 0)) elif yellow==2: img.draw_line(s.line(), color = (0, 255, 0)) else: img.draw_line(s.line(), color = (0, 0, 255)) if flag==1: break; elif flag==2: break; print(s) print("三角形") num_segment=1 flag =3 time.sleep(1000) break if flag == 0: print(flag) sending_data(flag,cr,yellow,k2,k4);
解决办法:time.sleep改为time.sleep_ms
原因,新的固件的api改了。
