代码运行时,图象十分卡顿,怎么处理?
一个用于形状及颜色识别和物块分拣的程序,运行时画面很卡
# Untitled - By: 41312 - 周四 1月 21 2021 import pyb import sensor, image, time,pyb from pyb import Servo sensor.reset() sensor.set_pixformat(sensor.RGB565) # grayscale is faster sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) clock = time.clock() L = 2500 M = 1500 R = 500 s1 = Servo(1)#上料 s2 = Servo(2)#左右分拣 s3 = Servo(3)#向下分拣 theresholds = (0, 100, -74, -21, -124, 127)#颜色阈值 s1.pulse_width(L)#Initialize def shangliao() : #上料 s1.pulse_width(M) pyb.delay(500) s1.pulse_width(L) pyb.delay(500) def xiafenjian(): #控制圆盘 s3.pulse_width(M) pyb.delay(500) s3.pulse_width(60) def zuofenjian(): #左分拣 s2.pulse_width(L) pyb.delay(500) s2.pulse_width(M) def youfenjian(): #右分拣 s2.pulse_width(R) pyb.delay(500) s2.pulse_width(M) def ShiBieColor(): #识别颜色 pass def circlefind() : #识别圆形 #lens_corr(1.8)畸变矫正 n=0 m=0 img = sensor.snapshot().lens_corr(1.8) for c in img.find_circles(threshold = 3200, x_margin = 10, y_margin = 10, r_margin = 10, r_min = 2, r_max = 100, r_step = 2): area = (c.x()-c.r(),c.y()-c.r(),2*c.r(),2*c.r()) statistics = img.get_statistics(roi=area) print(statistics) #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。 #l_mode(),a_mode(),b_mode()是L通道,A通道,B通道的众数。 if 0<statistics.l_mode()<100 and 0<statistics.a_mode()<127 and 0<statistics.b_mode()<127:#if the circle is red img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0)) n+=1 else: m+=1 if n>=3 : return 1 if m>=3 : return 0 def rectfind() : #识别矩形 n=0 c=0 img = sensor.snapshot().lens_corr(1.8) for r in img.find_rects(threshold = 25000): area = (r.rect()) statistics = img.get_statistics(roi=area) print(statistics) if 0<statistics.l_mode()<100 and 0<statistics.a_mode()<127 and 0<statistics.b_mode()<127:#if the retangle is red img.draw_rectangle(r.rect(),color =(0,0,0)) n+=1 else : c+=1 if n>=3 : return 1 if c>=3 : return 0 def shibie() : c = circlefind() r = rectfind() if c==1 : return 1 elif r==1 : return 2 else: return 3 while(True): clock.tick() shangliao() pyb.delay(200) Value = shibie() if(Value == 1) : xiafenjian() elif(Value == 2): zuofenjian() else: youfenjian pyb.delay(1500)
你的代码里那么多pyb.delay,当然会延迟很多。
