  • 没有看懂这些代码,能注释一下吗?
    • 1 import sensor, image, time, os, tf
      2
      3 sensor.reset() # Reset and initialize the sensor.
      4 sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
      5 sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240)
      6 sensor.set_windowing((240, 240)) # Set 240x240 window.
      7 sensor.skip_frames(time=2000) # Let the camera adjust.
      8
      9 net = "trained.tflite"
      10 labels = [line.rstrip('\n') for line in open("labels.txt")]
      11
      12 clock = time.clock()
      13 while(True):
      14 clock.tick()
      15
      16 img = sensor.snapshot()
      17
      18 for obj in tf.classify(net, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
      19 print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect())
      20 img.draw_rectangle(obj.rect())
      21 predictions_list = list(zip(labels, obj.output()))
      22 for i in range(len(predictions_list)):
      23 print("%s = %f" % (predictions_list[i][0], predictions_list[i][1]))
      24 print(clock.fps(), "fps")
      有几行代码没有看懂,第14、18-24行的代码能注释一下吗?
    • https://singtown.com/learn/50872/
      解释的很清楚了啊。
