  • ValueError: Pixel format is not supported!
    • Hello World Example
      Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script!
      sensor.set_pixformat(sensor.RGB565 ) # Set pixel format to RGB565 (or GRAYSCALE)
      sensor.skip_frames(time = 2000) # Wait for settings take effect.
      print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected
    • @kidswong999 显示灰度可以rgb565就会报错
    • @x1oq # Hello World Example
    • 你使用的是MT9V034吧?MT9V034只支持灰度,不支持彩色。
    • @kidswong999ValueError: Pixel format is not supported! 中说:
      MT9V034
      怎么看摄像头型号?
    • IDE最下面有传感器型号。
