星瞳实验室APP,快速收到回复
  • OSError: Region of interest is smaller than template!
      # NCC is not all to useful.
      import time, sensor, image
      # Reset sensor
      # Set sensor settings
      # Load template.
      template = image.Image("/2.pgm")   #我将这里的2改成了1(这个是我保存的模板)
      # Run template matching
          if r:
              img.draw_rectangle(r)
