星瞳实验室APP,快速收到回复
  • uncaught exception in Timer(2) interrupt handler,这种问题怎么解决呢
      import pyb
      from pyb import Timer, UART
      uart = UART(3, 115200, timeout_char = 1000)
      uart.init(115200, bits = 8, parity = None, stop = 1 )
      uart_buf = bytearray([0x55,0,0,0,0,0])
      def tick(timer):
          print("回调")
          uart.write(uart_buf)
          print("回调结束")
      senddata = Timer(2, freq = 100)
      senddata.callback(tick)
      # Tracks a black line. Use [(128, 255)] for a tracking a white line.
      GRAYSCALE_THRESHOLD = [(0, 64)]
      #设置阈值,如果是黑线,GRAYSCALE_THRESHOLD = [(0, 64)];
      #如果是白线,GRAYSCALE_THRESHOLD = [(128,255)]
      # Each roi is (x, y, w, h). The line detection algorithm will try to find the
      # centroid of the largest blob in each roi. The x position of the centroids
      # will then be averaged with different weights where the most weight is assigned
      # to the roi near the bottom of the image and less to the next roi and so on.
      ROIS = [ # [ROI, weight]
              (0, 100, 160, 20, 0.7), # You'll need to tweak the weights for you app
              (0, 050, 160, 20, 0.3), # depending on how your robot is setup.
              (0, 000, 160, 20, 0.1)
      #roi代表三个取样区域,(x,y,w,h,weight),代表左上顶点(x,y)宽高分别为w和h的矩形,
      #weight为当前矩形的权值。注意本例程采用的QQVGA图像大小为160x120,roi即把图像横分成三个矩形。
      #三个矩形的阈值要根据实际情况进行调整,离机器人视野最近的矩形权值要最大,
      #如上图的最下方的矩形,即(0, 100, 160, 20, 0.7)
      # Compute the weight divisor (we're computing this so you don't have to make weights add to 1).
      weight_sum = 0 #权值和初始化
      for r in ROIS: weight_sum += r[4] # r[4] is the roi weight.
      #计算权值和。遍历上面的三个矩形,r[4]即每个矩形的权值。
      # Camera setup...
      sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
      sensor.skip_frames(20) # Let new settings take affect.
      #关闭白平衡
          centroid_sum_x = 0
          centroid_sum_y = 0
          #利用颜色识别分别寻找三个矩形区域内的线段
          for r in ROIS:
              blobs = img.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True)
              # r[0:4] is roi tuple.
              #找到视野中的线,merge=true,将找到的图像区域合并成一个
              #目标区域找到直线
                  # Find the index of the blob with the most pixels.
                  most_pixels = 0
                  largest_blob = 0
                  for i in range(len(blobs)):
                  #目标区域找到的颜色块(线段块)可能不止一个,找到最大的一个,作为本区域内的目标直线
                      if blobs[i].pixels() > most_pixels:
                          most_pixels = blobs[i].pixels()
                          #merged_blobs[i][4]是这个颜色块的像素总数,如果此颜色块像素总数大于
                          #most_pixels,则把本区域作为像素总数最大的颜色块。更新most_pixels和largest_blob
                          largest_blob = i
                  img.draw_rectangle(blobs[largest_blob].rect())
                  #img.draw_rectangle((0,0,30, 30))
                  #将此区域的像素数最大的颜色块画矩形和十字形标记出来
                  img.draw_cross(blobs[largest_blob].cx(), blobs[largest_blob].cy())
                  centroid_sum_x += blobs[largest_blob].cx() * r[4] # r[4] is the roi weight.
                  centroid_sum_y += blobs[largest_blob].cy() * r[4]
                  #计算centroid_sum,centroid_sum等于每个区域的最大颜色块的中心点的x坐标值乘本区域的权值
          center_pos_x = int(centroid_sum_x / weight_sum) # Determine center of line.
          center_pos_y = int(centroid_sum_y / weight_sum)
          #print(center_pos_x, center_pos_x)
         # print(center_pos_x>>8, center_pos_x, center_pos_y>>8, center_pos_y)
          #中间公式
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
          uart_buf = ([0x55, center_pos_x>>8, center_pos_x, center_pos_y>>8, center_pos_y,0])
    • 来自星瞳实验室APP: MicroPython教程7-IO中断与回调函数 https://singtown.com/learn/582/
      你的中断服务程序里面有问题,变量需要加global修饰
