图像识别中程序识别结果出现的问题
# Edge Impulse - OpenMV Image Classification Example import sensor, image, time, os, tf sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((240, 240)) # Set 240x240 window. sensor.skip_frames(time=2000) # Let the camera adjust. from pyb import UART net = "trained.tflite" labels = [line.rstrip('\n') for line in open("labels.txt")] uart = UART(3, 115200) uart.init(115200, bits=8, parity=None, stop=1) clock = time.clock() while(True): if uart.any(): a=uart.readline().strip() clock.tick() time.sleep(1000) img = sensor.snapshot() for obj in tf.classify(net, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5): print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect()) img.draw_rectangle(obj.rect()) predictions_list = list(zip(labels, obj.output())) for i in range(len(predictions_list)): print("%s = %f" % (predictions_list[i][0], predictions_list[i][1])) max_size = predictions_list[0][1] zubie=0 for i in range(len(predictions_list)): if predictions_list[i][1] >= max_size: zubie=i+1 max_size=predictions_list[i][1] print(max_size) print(zubie) if a==b'\x01': data = bytearray([zubie]) uart.write(data) print(zubie)
为什么加了串口通信的语句之后,识别结果的概率和没加串口通信语句的概率差别这么大,没加的时候特别精确,但是加了之后老是出错
# Edge Impulse - OpenMV Image Classification Example import sensor, image, time, os, tf sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((240, 240)) # Set 240x240 window. sensor.skip_frames(time=2000) # Let the camera adjust. net = "trained.tflite" labels = [line.rstrip('\n') for line in open("labels.txt")] clock = time.clock() while(True): clock.tick() img = sensor.snapshot() # default settings just do one detection... change them to search the image... for obj in tf.classify(net, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5): print("**********\nPredictions at [x=%d,y=%d,w=%d,h=%d]" % obj.rect()) img.draw_rectangle(obj.rect()) # This combines the labels and confidence values into a list of tuples predictions_list = list(zip(labels, obj.output())) for i in range(len(predictions_list)): print("%s = %f" % (predictions_list[i][0], predictions_list[i][1])) print(clock.fps(), "fps")
是两个代码的:print("%s = %f" % (predictions_list[i][0], predictions_list[i][1]))
这一句的结果不一样?
