# Multi Color Blob Tracking Example
# This example shows off multi color blob tracking using the OpenMV Cam.
# The below thresholds track in general red/green things. You may wish to tune them...
(15, 84, -53, -10, -30, 20), # generic_green_thresholds
(47, 75, -128, 21, 31, 127)] # generic_blue_thresholds
# You may pass up to 16 thresholds above. However, it's not really possible to segment any
# scene with 16 thresholds before color thresholds start to overlap heavily.
# camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=1000):
if blob.elongation() > 0.5:
img.draw_edges(blob.min_corners(), color=(255,0,0))
img.draw_line(blob.major_axis_line(), color=(0,255,0))
img.draw_line(blob.minor_axis_line(), color=(0,0,255))
print(blob.area())
time.sleep(1000)
