  • 口罩识别,提示MemoryError: Out of fast Frame Buffer Stack Memory!
    • openmv4 H7 按照教程做的口罩识别,运行程序的时候显示MemoryError: Out of fast Frame Buffer Stack Memory! Please reduce the resolution of the image you are running this algorithm on to bypass this issue!0_1605587511918_59a9060c-9acf-4101-8e0c-5c7c65f5bcd7-image.png
      已经插入SD卡了,这是什么问题。
      net = "trained.tflite"
          print(clock.fps(), "fps")
    • 只能用OpenMV4 Plus,OpenMV4 用不了。
    • 那怎么解决,教程中用的不是4吗?
    • @kidswong999 没有plus怎么做识别呢
