  • 利用以下代码和接线方式完成arduino和openmv通信,为什么arduino串口显示的是乱码?
    • 我的接线方式是arduino和openmv先分别连在同一个电脑上,然后他们之间用三根杜邦线连接起来,arduino的10、11连openmv的p4、p5,还有一根线是arduino的GND连openmv的GND。
      这是openmv代码
      yellow_threshold   = ( 46,  100,  -68,   72,   58,   92)
              #print('sum : %d'% len(blobs))
              data=[]
              for b in blobs:
                  img.draw_rectangle(b.rect()) # rect
                  img.draw_cross(b.cx(), b.cy()) # cx, cy
                  data.append((b.cx(),b.cy()))
              #{(1,22),(-3,33),(22222,0),(9999,12),(0,0)}
              data_out = json.dumps(set(data))
              uart.write(data_out +'\n')
              print('you send:',data_out)
              print("not found!")
      这是arduino代码
      #include <SoftwareSerial.h>
      SoftwareSerial softSerial(10, 11); // RX, TX
      typedef struct
        int data[50][2] = {{0,0}};
        int len = 0;
      }List;
      List list;
      void setup() {
        // put your setup code here, to run once:
        softSerial.begin(9600);
        Serial.begin(9600);
      void loop() {
        if(softSerial.available())
          getList();
          for (int i=0; i<list.len; i++)
            Serial.print(list.data[i][0]);
            Serial.print('\t');
            Serial.println(list.data[i][1]);
          Serial.println("============");
          clearList();
      String detectString()
        while(softSerial.read() != '{');
        return(softSerial.readStringUntil('}'));
      void clearList()
        memset(list.data, sizeof(list.data),0);
        list.len = 0;
      void getList()
        String s = detectString();
        String numStr = "";
        for(int i = 0; i<s.length(); i++)
          if(s[i]=='('){
            numStr = "";
          else if(s[i] == ','){
            list.data[list.len][0] = numStr.toInt();
            numStr = "";
          else if(s[i]==')'){
            list.data[list.len][1] = numStr.toInt();
            numStr = "";
            list.len++;
          else{
            numStr += s[i];
      0_1603526603772_QQ截图20201024155640.png 0_1603526616295_QQ截图20201024155706.png
    • 你的波特率不匹配呀。
