为什么不能在List数组尾部增加数字1
代码是这样的
# Select an area in the Framebuffer to copy the color settings. #from machine import I2C #from vl53l1x import VL53L1X import time from pid import PID from pyb import UART import math import json clock = time.clock() # Tracks FPS. # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... #i2c = I2C(2) #distance = VL53L1X(i2c) x_pid = PID(p=0.05, i=0.05, imax=100) d_pid = PID(p=0.05, i=0.1, imax=50) #uart1 = UART(3, 9600,timeout=1000) uart1=UART(3, 9600) uart1.init(9600, bits=8, parity=None, stop=1) uart2=UART(1, 9600) uart2.init(9600, bits=8, parity=None, stop=1) List=list() while(True): # clock.tick() # Track elapsed milliseconds between snapshots(). List=[1] if uart1.any(): # x_error =uart1.readline().decode() x_error = int(uart1.read().decode()) print(x_error) SET=600 # x_output=x_pid.get_pid(x_error,1) # print(x_output) if(x_error>=9999): a=len(List) D_24=0 D_13=0 List.append=("1") a=len(List) if(a>=3): FH = bytearray([57,168]) uart2.write(FH) data = bytearray([27,27,27,27,60,5,60,5]) ### uart2.write(data) print(int(D_13),int(D_24)) else: List=[0,] if(abs(x_error)>SET): x_output=d_pid.get_pid(x_error,1) D_24=-x_output ### D_13=x_output ### if((D_13)>=0): a=5 else: a=60 if((D_24)>=0): b=5 else: b=60 # FH = bytearray([168,168]) # uart2.write(FH) D_13=abs(D_13) D_24=abs(D_24) if((D_13)>35): D_13=35 if((D_24)>35): D_24=35 FH = bytearray([57,168]) uart2.write(FH) data = bytearray([int(D_13),int(D_24),int(D_13),int(D_24),a,b,a,b]) ### uart2.write(data) # print(int(D_13),int(D_24),a,b,a,b) else: # x_output=x_pid.get_pid(x_error,1) # print(x_output) theta_default=0.5*math.pi # 0.5*3.14 # l_threshold=100 ##### delta_theta_max=0.785 a=delta_theta_max/SET # print(a) # x_output=x_pid.get_pid(x_error,1) delta_theta=a*x_error # d = distance.read() # print(d) k=30 #### D_14=k*(math.cos(theta_default+delta_theta)+math.sin(theta_default+delta_theta)) D_23=k*(math.sin(theta_default+delta_theta)-math.cos(theta_default+delta_theta)) # print(D_14,D_23) FH = bytearray([57,168]) uart2.write(FH) data = bytearray([int(D_14),int(D_23),int(D_23),int(D_14),5,5,5,5]) uart2.write(data) print(int(D_14),int(D_23),int(D_23),int(D_14),5,5,5,5)
会报错:AttributeError: 'NoneType' object has no attribute 'append'
你的数组的列表操作都是错的。建议重新学一下语法:https://www.runoob.com/python3/python3-list.html
44行,List.append=("1"),append是函数,应该是List.append("1"),而且为啥是字符串,应该改为List.append(1)。
