OSError:Descriptors have different type怎么解决
调试人脸识别代码时同一条语句不定时出现不同错误。还有其他奇奇怪怪的bug也都不定时出现。运气好时可以连续运行一个小时。运气不好时一打开就崩溃。而且有时不报错直接崩
# Face recognition with LBP descriptors. # See Timo Ahonen's "Face Recognition with Local Binary Patterns". # # Before running the example: # 1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip # 2) Exract and copy the orl_faces directory to the SD card root. import sensor, time, image, pyb sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.GRAYSCALE) # or sensor.GRAYSCALE sensor.set_framesize(sensor.B128X128) # or sensor.QQVGA (or others) sensor.set_windowing([0,0,127,127])#((92,112)) sensor.skip_frames(10) # Let new settings take affect. sensor.skip_frames(time = 5000) #等待5s sensor.set_contrast(1) sensor.set_gainceiling(16) face_cascade = image.HaarCascade("frontalface", stages=25) #SUB = "s1" NUM_SUBJECTS = 6 #图像库中不同人数,一共6人 NUM_SUBJECTS_IMGS = 20 #每人有20张样本图片 # 拍摄当前人脸。 #img = sensor.snapshot() ##img = image.Image("singtown/%s/1.pgm"%(SUB)) #d0 = img.find_lbp((0, 0, img.width(), img.height())) #d0为当前人脸的lbp特征 img = None pmin = 999999 num=0 def min(pmin, a, s): global num if a<pmin: pmin=a num=s return pmin def max_face(objects): face2=0 for face1 in objects: face2=face1; #if i==0: #face2=objects[0] #i=1; #elif face1.w<objects[i].w: #face2=objects[i] return face2; face=[0,0,127,127] dist = 0 while(True): img = sensor.snapshot() objects = img.find_features(face_cascade, threshold=1.3, scale=1.5) #face=max_face(objects); if len(objects)==1: for face in objects: print(objects) img.draw_rectangle(face); if face[3]<50: continue; elif face[2]>55: continue; sensor.set_windowing(face) d0 = img.find_lbp(face) #((0, 0, img.width(), img.height())) pmin=9999999; for s in range(1, NUM_SUBJECTS+1): dist = 0 for i in range(2, NUM_SUBJECTS_IMGS+1): img = image.Image("singtown/s%d/%d.pgm"%(s, i)) #pgm d1 = img.find_lbp((0, 0, img.width(), img.height())) #d1为第s文件夹中的第i张图片的lbp特征 dist += image.match_descriptor(d0, d1)#计算d0 d1即样本图像与被检测人脸的特征差异度。 print("Average dist for subject %d: %d"%(s, dist/NUM_SUBJECTS_IMGS)) pmin = min(pmin, dist/NUM_SUBJECTS_IMGS, s)#特征差异度越小,被检测人脸与此样本更相似更匹配。 print(pmin) print(num) # num为当前最匹配的人的编号。 sensor.set_windowing([0,0,127,127])#((92,112)) sensor.skip_frames(time = 200)
你用的是什么硬件,什么版本固件?
H7的 固件是3.6.8
刚刚又爆了个错误 但是忘截图了
@kidswong999 我刚刚又换了个F7试了下 依然存在若干bug随机出现的问题 再比如还有这个:
@kidswong999 实在不会了。救救孩子吧
