  • 云台上下可以动,左右不能动,示波器显示有PWM波
    • # Motor Shield PWM Example
      # This example shows off how to control the motor shield on your
      # OpenMV Cam. The motor shield is controlled by using the PYB module
      # which lets you do PWM to control the speed and set digital I/O pin
      # states. The motor shield needs 6 I/O pins for both motors.
      import pyb
      #from pyb import Pin, Timer
      tim = pyb.Timer(4, freq=50)
      chA = tim.channel(1, pyb.Timer.PWM, pin=pyb.Pin("P7"))#
      chB = tim.channel(2, pyb.Timer.PWM, pin=pyb.Pin("P8"))
      times = 500
      while (times >1):
          chA.pulse_width_percent(40)#
          chB.pulse_width_percent(30)#
          times = times - 1
          pyb.delay(10)
      chA.pulse_width_percent(0)#向前
      chB.pulse_width_percent(0)#
    • https://singtown.com/learn/49603/
      云台按照这个视频操作。
      https://singtown.com/learn/50541/
      舵机按照这个视频测试。
