TypeError: 'int' object isn't callable 出现莫名奇妙的问题
我是前几天帖子的帖主,这次是进行人脸识别,为了提高人脸抓取的准确性,在人脸识别的基础上进行eyes的判断,每次进行人脸计算的时候就会在min函数的调用时出现TypeError: 'int' object isn't callable的报错,属实是有些莫名其妙。希望得到官方的解答,另:论坛无法上传20张人脸库,如若测试代码,在base文件中创建s1、s2两个文件夹存储20张图片即可。
import sensor, image, time, pyb from pyb import Pin red = pyb.LED(1) #初始化led green = pyb.LED(2) blue = pyb.LED(3) yellow= pyb.LED(4) sensor.reset() #传感器重置 sensor.set_contrast(3) #感光元件设置 sensor.set_gainceiling(16) sensor.set_pixformat(sensor.GRAYSCALE) #图像格式为灰度值 sensor.set_framesize(sensor.QQVGA) #图像大小为HQVGA,用于人脸识别 sensor.set_vflip(True) sensor.skip_frames(time = 3000) #等待sensor稳定 face_cascade = image.HaarCascade("frontalface", stages=25) #载入人脸识别模型 eyes_cascade = image.HaarCascade("eye", stages=24) #载入人眼识别模型 clock = time.clock() #初始化系统时钟 p = pyb.Pin("P8", pyb.Pin.OUT_PP) def tick(timer): p.high() pyb.delay(1) p.low() tim=pyb.Timer(4) tim.init(freq=1) tim.callback(tick) count=0 #每个人拍50张照片 person=1 #不同编号的人 person_base=1 #数据库人数 person_base_total=2 #数据库总人数 person_base_total_count=0 #数据库总人数(变量) dist_once=0 #lbp差异值 num_final=0 #最终匹配编号 num_once=0 #单次匹配编号 pmin = 999999 #最小值初始化 detect_1=0 detect_2=0 def min(pmin, a, s): global num_once if a<pmin: pmin=a num_once=s return pmin while(True): #系统主循环 clock.tick() img = sensor.snapshot() objects = img.find_features(face_cascade, threshold=0.75, scale=1.35) if objects: face_find=objects[0] if face_find[2]>=81 and face_find[3]>=81: red.on() pmin=999999 sensor.set_windowing(objects[0]) eyes = img.find_features(eyes_cascade, threshold=0.5, scale_factor=1.2, roi=objects[0]) if eyes: for snapshot_save in range(1,31): sensor.snapshot().save("now/s%s/%s.pgm" % (1,snapshot_save ) ) print(snapshot_save,':',face_find[2],face_find[3]) num_final=0 detect_1=0 detect_2=0 for s_now in range(1,31): pmin=99999 num_once=0 img_now=image.Image("now/s%d/%d.pgm"%(1, s_now)) d_now=img_now.find_lbp((0, 0, 81, 81)) for person_base_total_count in range(1,person_base_total+1): dist_once=0 for s_base in range(1,21): img_base=image.Image("base/s%d/%d.pgm"%(person_base_total_count, s_base)) d_base=img_base.find_lbp((0, 0, 81, 81)) dist_once += image.match_descriptor(d_now, d_base) dist_ave=dist_once/20 print(s_now,':',person_base_total_count,':',dist_ave) pmin=min(pmin,dist_ave,person_base_total_count) if num_once==1: detect_1+=1 if num_once==2: detect_2+=1 print('the number of photo is:',s_now,':',num_once) print('the number of person 1:',detect_1,'the number of person 2:',detect_2) if detect_1>=detect_2: num_final=1 if detect_1<detect_2: num_final=2 print('this person is number:',num_final) if num_final==1: green.on() elif num_final!=1: blue.on() else: red.off() sensor.set_windowing((0,0,160,120)) else: red.off() sensor.set_windowing((0,0,160,120)) green.toggle()
有没有复现错误的步骤?
或者提供直接就报错的代码。我运行程序没有出现任何输出,可能是if没有运行到最后。
