为什么扫码条形码和二维码摄像头拍出来的东西很模糊连信息都识别不出来用的是上手教程里面给的代码信息根本识别不出来
sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.VGA) # High Res! sensor.set_windowing((640, 120)) # V Res of 80 == less work (40 for 2X the speed). sensor.skip_frames(time=2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... sensor.set_auto_whitebal(False) # must turn this off to prevent image washout... clock = time.clock() # Barcode detection can run at the full 640x480 resolution of your OpenMV Cam's # OV7725 camera module. Barcode detection will also work in RGB565 mode but at # a lower resolution. That said, barcode detection requires a higher resolution # to work well so it should always be run at 640x480 in grayscale... def barcode_name(code): if(code.type() == image.EAN2): return "EAN2" if(code.type() == image.EAN5): return "EAN5" if(code.type() == image.EAN8): return "EAN8" if(code.type() == image.UPCE): return "UPCE" if(code.type() == image.ISBN10): return "ISBN10" if(code.type() == image.UPCA): return "UPCA" if(code.type() == image.EAN13): return "EAN13" if(code.type() == image.ISBN13): return "ISBN13" if(code.type() == image.I25): return "I25" if(code.type() == image.DATABAR): return "DATABAR" if(code.type() == image.DATABAR_EXP): return "DATABAR_EXP" if(code.type() == image.CODABAR): return "CODABAR" if(code.type() == image.CODE39): return "CODE39" if(code.type() == image.PDF417): return "PDF417" if(code.type() == image.CODE93): return "CODE93" if(code.type() == image.CODE128): return "CODE128" while(True): clock.tick() img = sensor.snapshot() codes = img.find_barcodes() for code in codes: img.draw_rectangle(code.rect()) print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps()) print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args) if not codes: print("FPS %f" % clock.fps()) 请在这里粘贴代码
要对焦距。看一下视频:https://singtown.com/learn/50017/
