使用MV4 H7 PLUS,提示:RuntimeError:Capturn Failed:-4,需要重新连接,怎么解决?
import sensor, image, time, math,lcd,pyb from pyb import UART import json import ustruct sensor.reset() sensor.set_framesize(sensor.QVGA) sensor.set_pixformat(sensor.RGB565) sensor.skip_frames(time = 2000) lcd.init() clock = time.clock() uart = UART(3,115200) #定义串口3变量 P4 TX<-->PA10 P5 RX<-->PA9 uart.init(115200, bits=8, parity=None, stop=1) # init with given parameters find_threshold = (35, 9, -5, 6, 28, 13) def find_max(blobs): blobs.sort(key=lambda x:x.pixels(),reverse=True); max_blob={} length=len(blobs) if length>0: max_blob=blobs[0] return max_blob def sending_data(cx_max,cy_max): global uart; #frame=[0x2C,18,cx%0xff,int(cx/0xff),cy%0xff,int(cy/0xff),0x5B]; #data = bytearray(frame) data = ustruct.pack("<bbhhb", 0x2C, 0x12, int(cx_max), # up sample by 4 int(cy_max), # up sample by 4 0x5B); uart.write(data); while(True): clock.tick() lcd.display(sensor.snapshot()) img = sensor.snapshot()#.lens_corr(1.3); #img.binary([binary_threshold], invert = 1) blobs = img.find_blobs([find_threshold],area_threshold=100,pixel_threshold=8000) if blobs: max_blob=find_max(blobs) img.draw_rectangle(max_blob.rect(),color=(0,0,255)) img.draw_cross(max_blob.cx(), max_blob.cy(),color=(0,0,255)) img.draw_cross(160, 120,color=(255,0,0)) # 在中心点画标记 img.draw_line((160,120,max_blob.cx(),max_blob.cy()), color=(0,0,255)); img.draw_circle(160, 120, 10, color = (255,0,0), thickness = 1, fill = False) xywh=max_blob.rect() print("xywh=",xywh) print("中心x坐标:",max_blob.cx(),"中心y坐标:",max_blob.cy()) print("L =", 160 - max_blob.cx()) print("H =", 120 - max_blob.cy()) print("像素数量:",max_blob.pixels()) print("\r\n") print(clock.fps())
但是我用其他的openmv却能正常运行;
报错的是:openmv4 cam h7 plus
正常的是:openmv4 cam h7
你有没有把PLUS的摄像头模组的两个螺丝拧紧?我感觉像是摄像头模组没有安装紧固。
