定时器函数内读取图像出错为什么?
# Untitled - By: Dell - 周四 9月 3 2020 import sensor, image, time from pyb import Pin, Timer,LED import math sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.VGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(True) # must be turned off for color tracking sensor.set_auto_whitebal(True) # must be turned off for color tracking clock = time.clock() blue_led = LED(3) red_led = LED(1) ROI = (200,80,240,280) # 定义感兴趣范围 MY_AREA=ROI def tick1(timer): red_led.toggle() img = sensor.snapshot() img.draw_rectangle(MY_AREA) tim = Timer(2, freq=0.2) # 使用定时器2创建定时器对象-以1Hz触发 tim.callback(tick1) #tim.callback(lambda t:tick()) # 将回调设置为tick函数 while (True): img = sensor.snapshot() img.draw_rectangle(MY_AREA) time.sleep(10)
原因:中断服务函数里不应该有新增变量。
参考:https://docs.singtown.com/micropython/zh/latest/openmvcam/reference/isr_rules.html解决办法:中断服务函数应该尽量短,不应该有采集图像和处理图像。
可以运行的代码:
import sensor, image, time from pyb import Pin, Timer,LED import math sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.VGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(True) # must be turned off for color tracking sensor.set_auto_whitebal(True) # must be turned off for color tracking clock = time.clock() blue_led = LED(3) red_led = LED(1) ROI = (200,80,240,280) # 定义感兴趣范围 MY_AREA=ROI def tick1(timer): global red_led red_led.toggle() tim = Timer(2, freq=0.2) # 使用定时器2创建定时器对象-以1Hz触发 tim.callback(tick1) #tim.callback(lambda t:tick()) # 将回调设置为tick函数 while (True): img = sensor.snapshot() img.draw_rectangle(MY_AREA) time.sleep(10)
