  • AttributeError: 'NoneType' object has no attribute 'theta'
    • THRESHOLD = (153, 255) # Grayscale threshold for dark things...
      #设置是否使用img.binary()函数进行图像分割
      BINARY_VISIBLE = True # 首先执行二进制操作,以便您可以看到正在运行的线性回归
          img = sensor.snapshot().binary([THRESHOLD]) if BINARY_VISIBLE else sensor.snapshot()
          singleline_check = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD],robust = True)
          if (singleline_check): img.draw_line(singleline_check.line(), color = 127)
          print("FPS %f, mag = %s" % (clock.fps(), str(singleline_check.magnitude()) if (singleline_check) else "N/A"))
          print(singleline_check.theta(),singleline_check.rho())
    • 报错指向最后一行代码,有的时候程序能够正常运行,可以输出最后一行代码的两个值
    • 这个提示很清楚了,因为singleline_check有时候是None,所以改一下代码,加一个判断就行:
              print("mag = %s" % str(singleline_check.magnitude()))
          print("fps:", clock.fps())
    • @kidswong999 原来如此,谢谢!
