AprilTag测距准确性问题,是否需要做相机参数校准标定?
使用find_apriltags_3d_pose例程来获取AprilTag相对于相机的6-DOF位姿,但是当相机保持固定,在和相机距离恒定的墙面上移动AprilTag(从视野到边缘)却发现Z方向位移值一直有变化,理论上这不应该呀,这个误差是由什么造成的呢?是和镜头畸变有关吗?但是例程注释里说识别AprilTag不需要对相机做校准呀。
z方向是标签和OpenMV的距离轴。这个是通过画面中的大小计算的。
你提供一下具体的代码,误差数据,
和实际场景的照片,和OpenMV画面里标签的大小的照片。
代码就是IDE中AprilTag定位的例程(位移乘了个k换算成了实际距离):
# AprilTags Example # # This example shows the power of the OpenMV Cam to detect April Tags # on the OpenMV Cam M7. The M4 versions cannot detect April Tags. import sensor, image, time, math sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) # we run out of memory if the resolution is much bigger... sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... sensor.set_auto_whitebal(False) # must turn this off to prevent image washout... clock = time.clock() tag_families = 0 tag_families |= image.TAG16H5 # comment out to disable this family tag_families |= image.TAG25H7 # comment out to disable this family tag_families |= image.TAG25H9 # comment out to disable this family tag_families |= image.TAG36H10 # comment out to disable this family tag_families |= image.TAG36H11 # comment out to disable this family (default family) tag_families |= image.ARTOOLKIT # comment out to disable this family # What's the difference between tag families? Well, for example, the TAG16H5 family is effectively # a 4x4 square tag. So, this means it can be seen at a longer distance than a TAG36H11 tag which # is a 6x6 square tag. However, the lower H value (H5 versus H11) means that the false positve # rate for the 4x4 tag is much, much, much, higher than the 6x6 tag. So, unless you have a # reason to use the other tags families just use TAG36H11 which is the default family. def family_name(tag): if(tag.family() == image.TAG16H5): return "TAG16H5" if(tag.family() == image.TAG25H7): return "TAG25H7" if(tag.family() == image.TAG25H9): return "TAG25H9" if(tag.family() == image.TAG36H10): return "TAG36H10" if(tag.family() == image.TAG36H11): return "TAG36H11" if(tag.family() == image.ARTOOLKIT): return "ARTOOLKIT" # Note! Unlike find_qrcodes the find_apriltags method does not need lens correction on the image to work. # What's the difference between tag families? Well, for example, the TAG16H5 family is effectively # a 4x4 square tag. So, this means it can be seen at a longer distance than a TAG36H11 tag which # is a 6x6 square tag. However, the lower H value (H5 versus H11) means that the false positve # rate for the 4x4 tag is much, much, much, higher than the 6x6 tag. So, unless you have a # reason to use the other tags families just use TAG36H11 which is the default family. # The AprilTags library outputs the pose information for tags. This is the x/y/z translation and # x/y/z rotation. The x/y/z rotation is in radians and can be converted to degrees. As for # translation the units are dimensionless and you must apply a conversion function. # f_x is the x focal length of the camera. It should be equal to the lens focal length in mm # divided by the x sensor size in mm times the number of pixels in the image. # The below values are for the OV7725 camera with a 2.8 mm lens. # f_y is the y focal length of the camera. It should be equal to the lens focal length in mm # divided by the y sensor size in mm times the number of pixels in the image. # The below values are for the OV7725 camera with a 2.8 mm lens. # c_x is the image x center position in pixels. # c_y is the image y center position in pixels. f_x = (2.8 / 3.984) * 160 # find_apriltags defaults to this if not set f_y = (2.8 / 2.952) * 120 # find_apriltags defaults to this if not set c_x = 160 * 0.5 # find_apriltags defaults to this if not set (the image.w * 0.5) c_y = 120 * 0.5 # find_apriltags defaults to this if not set (the image.h * 0.5) def degrees(radians): return (180 * radians) / math.pi while(True): clock.tick() img = sensor.snapshot() for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # defaults to TAG36H11 img.draw_rectangle(tag.rect(), color = (255, 0, 0)) img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0)) print_args = (family_name(tag), tag.id(), tag.x_translation()*4.317, tag.y_translation()*4.317, tag.z_translation()*4.317, \ degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation())) # Translation units are unknown. Rotation units are in degrees. print("Tag Family %s, Tag ID %d, Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args) print(clock.fps())
场景和结果如图,AprilTag紧贴墙平移,OpenMV固定在和墙平移距墙恒定的位置,按说Ty Tz应该在平移过程中保持不变,但尤其Z方向,有一个0.5cm左右的误差
@kidswong999 代码和图片如上,场景图片显示失败,就是AprilTag靠墙平移,摄像头粘在盒子上固定在和墙平行且距离恒定的位置。
那请问X和Y方向是怎么实现定位的呢?可以提供底层代码吗?
@kidswong999
那请问对如图的Y和Z方向的误差的原因,有什么见解呢?
