  • 'int' object isn't subscriptable是什么问题
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      template = image.Image("/2.pgm")
          blobs = img.find_template(template, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
              img.draw_rectangle(r)(max_blob)
    • img.draw_rectangle(r)(max_blob)
      这句明显错了
