为什么openmv串口发送给51单片机数据点灯也点不亮
有人能帮忙看下么
THRESHOLD = ((24, 97, -25, 100, -128, 127)) # Grayscale threshold for dark things... import sensor, image, time from pyb import LED from pid import PID from pyb import UART rho_pid = PID(p=0.4, i=0) theta_pid = PID(p=0.08, i=0) uart = UART(3, 9600) LED(1).on() LED(2).on() LED(3).on() sensor.reset() sensor.set_vflip(True) sensor.set_hmirror(True) sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000. #sensor.set_windowing([0,20,80,40]) sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds clock = time.clock() # to process a frame sometimes. while(True): clock.tick() img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100,0,0,0,0)], robust = True)#返回一条直线对象 if (line): rho_err = abs(line.rho())-img.width()/2 #直线左右偏移距离,需要调整到视野中央 if line.theta()>90: theta_err = line.theta()-180 #与y轴平行的方向,即0° else: theta_err = line.theta() print(theta_err) #FH = bytearray([0xb3,0xb3]) #uart.write(FH) uart.write((str(theta_err)))
下面是51单片机的接受代码
#include "reg52.h" typedef unsigned int u16; typedef unsigned char u8; static u8 Temp; //定义临时变量 static u16 a; sbit led1=P2^0; sbit led2=P2^1; sbit led3=P2^2; void UsartInit() { TMOD=0X20; SCON=0X50; TH1=0XFD; TL1=TH1; PCON=0X00; TR1=1; ES=1; EA=1; } void main() { UsartInit(); while(1) { } } /*------------------------------------------------ 发送一个字节 ------------------------------------------------*/ void SendByte(unsigned char dat) { SBUF = dat; while(!TI); TI = 0; } /*------------------------------------------------ 发送一个字符串 ------------------------------------------------*/ void SendStr(unsigned char *s) { while(*s!='\0')// \0 表示字符串结束标志,通过检测是否字符串末尾 { SendByte(*s); s++; } } void Usart() interrupt 4 { if(RI) //判断是接收中断产生 { RI=0; //标志位清零 Temp=SBUF; a=SBUF; if(-6<a<3) { led2=0; } if(a<=-6) { led1=0; } else { led3=0; } } else { TI=0; } }
我没办法测试不同的单片机的程序。
建议检查的步骤。
1,检查OpenMV代码:通过串口调试扩展板或者示波器查看数据,证明OpenMV有数据传出。
https://singtown.com/learn/50240/2,检查51的代码:通过串口模块手动发送数据给51单片机,测试单片机的程序对不对。这部分找相应的资料,我们没有。
3,检查连线,tx,rx是否连反了,gnd是否没共地。
