新买的open mv 连接不上IED,以前的板子就没问题,提示如下图。怎么才能连接上?
# AprilTags Example # # This example shows the power of the OpenMV Cam to detect April Tags # on the OpenMV Cam M7. The M4 versions cannot detect April Tags. import sensor, image, time, math sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) # we run out of memory if the resolution is much bigger... sensor.skip_frames(30) sensor.set_auto_gain(False) # must turn this off to prevent image washout... sensor.set_auto_whitebal(False) # must turn this off to prevent image washout... clock = time.clock() while(True): clock.tick() img = sensor.snapshot() for tag in img.find_apriltags(): # defaults to TAG36H11 without "families". img.draw_rectangle(tag.rect(), color = (255, 0, 0)) img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0)) degress = 180 * tag.rotation() / math.pi print(tag.id(),degress)
你看一下文件管理器里面,有没有OpenMV的磁盘?
@kidswong999 有的,我怕卡会影响它所以我用的一个卡
你换一个电脑试一下,
如果不行就重新烧录固件试一下,https://singtown.com/learn/50661/
如果还不行就联系售后寄回维修。
