我想问问,我通过识别出圆形再识别颜色,来识别围棋棋子,为什么识别情况很不稳定
import sensor, image, time import math from mywuzi import chess from movement import move from movement import cgj from pyb import UART uart=UART(1,9600) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() chess1 = [[0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0], [0,0,0,0,0,0,0,0,0,0]] while(True): clock.tick() img = sensor.snapshot().lens_corr(1.8) for c in img.find_circles(threshold = 1500, x_margin = 10, y_margin = 10, r_margin = 10, r_min = 0, r_max = 7, r_step = 2): area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r()) #area为识别到的圆的区域,即圆的外接矩形框 statistics = img.get_statistics(roi=area)#像素颜色统计 #(0,20,-20,20,-10,20)是黑色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是黑棋。 #l_mode(),a_mode(),b_mode()是L通道,A通道,B通道的众数。 if c.r() <= 6: if 0<statistics.l_mode()<26 and -28<statistics.a_mode()<22 and -47<statistics.b_mode()<29:#if the circle is black img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的黑棋用红色的圆框出来 m1 = (c.x()-32)/12 m2 = (c.x()-20)/12 m = int(m2) n1 = (106-c.y())/12 n2 = (118-c.y())/12 n = int(n2) chess1[m][n] = -1 else: img.draw_rectangle(area, color = (255, 255, 255))#将白棋用白色的矩形框出来 m1 = (c.x()-32)/12 m2 = (c.x()-20)/12 m = int(m2) n1 = (106-c.y())/12 n2 = (118-c.y())/12 n = int(n2) chess1[m][n] = 1
具体的图片发一下。
@kidswong999 不稳定,总是闪烁
你可以把OpenMV固定在棋盘上面,就可以直接找到对应位置的颜色。就不用找圆。
